Hardner shelf life?
Duane(Pa)
10-21-2007 19:34:28
Did I read somewhere that Paint Hardner has a limited shelf life? Have some a couple years old.
CNKS
10-22-2007 06:51:45
 Re: Hardner shelf life? in reply to Duane(Pa), 10-21-2007 19:34:28
I believe it's 2? years unopened, 2 weeks opened. But, you can put it in the refrigerator and/or squirt a gas such as bloxygen (trade name), or some forms of welding gas (I'm not a welder) immediately before you close it and it will last indefinitely. I do that, but usually replace after a few months to be on the safe side. Some controversy about this as I have heard of people using it for a couple of years with no gas or refrigeration. However a small refrigerator costs less than $100 and uses little electricity. If you see crystals in it I definitely wouldn't use it, not sure if that is the deciding factor, though.
Damp;Dservice
10-21-2007 20:17:37
After you open it for the first time, It isnt very long before its hard in the can, I use dupont but most is the same, if its not hard i would use it, but it has probably got small chrystals of hardened material in it, makes paint look yuk!
