Hi Randy, Whenever I spray latex I use Sherwin Williams Duration acrylic latex, applied with Graco high pressure airless spray equipment. I wouldn't attempt it with any air-atomized gun that I use for automotive paints. I know that would fail miserably. Yes, the Graco is best for large jobs and I find it a pain to clean, even when using only latex - it takes me at least an hour to clean up the equipment afterwards. For small Latex jobs, I really don't have a spray recommendation. I use brush or roller application for those. If outside, I have to be in the shade on a cool day though since the Duration can dry so fast that it's difficult to keep a wet edge with either a brush or a roller. Inside generally isn't a problem keeping a wet edge as long as you keep at it. Sherwin Williams doesn't recommend anything other than brush, roller or 2000 psi airless spray - at least for their Duration product. Perhaps other Latex products are a little bit thinner than Duration so you might want to check the SW website for a tech data sheet on the exact product you are using. I've never used one of the small, portable Wagner units. I started to look into them once for some interior wall work but decided against that in favor of brush and roller. I think you are going to have a hard time finding any air-atomized equipment that would be a suitable substitute for high pressure airless. Check the manufacturer's instructions regarding thinning. The Duration I use is not to be thinned. However, if you can thin the latex you use down into the 20-24 second area using a #2 Zahn viscosity cup, you could then apply that with conventional automotive-type air-atomized spray equipment. I don't know if you can or should do that with any latex paint but that would be one solution if you could get away with it. Rod
