oil pan dent
Mike CA
11-10-2007 21:07:02
I bought an oil pan for my '44 Farmall H at a junkyard. It has a double dent on the bottom towards the back. I can see it poking through on the inside. Also, the area around the drain plug seems to be caved in a bit.
I've never done any bodywork on anything, but I'd like to straighten out this pan before I put it on the tractor.
What do I do?
Mike CA
11-10-2007 21:07:45
 Re: oil pan dent in reply to Mike CA, 11-10-2007 21:07:02
Oh, I forgot to mention, I have very limited tools. So anything fancy or high tech I probably won't have.
B-maniac
11-11-2007 09:27:38
 Re: oil pan dent in reply to Mike CA, 11-10-2007 21:07:45
They are made of pretty heavy guage metal. No special tools required. Just a hammer and a heavy "back up" to flatten it out. When straightened best you can then grind the outside to smooth out the slight dimples if any. Common sense is the most "high tech" tool you will need in most operations on these old tractors. Without it , good luck!!
