DH; Here are the codes courtesy of Rod(NH). Rod is a knowledgeable and respected contributor to this site. He as well as others have been a tremendous help to me and others. Below is a Caution he gives as well as the PPG Oliver Codes. PPG Automotive Finishes Tractor and Implement Colors
"Caution: This list was assembled using three different PPG sources plus input from others. There was no information concerning model or year, except as noted. Use this list at your own risk. There are no guarantees. I have only confirmed the AC early persian orange, sometimes referred to as "persian #1", as 60080. Most of the codes should be available in most, if not all, current PPG automotive paint chemistries, including the economy OMNI line. See your local PPG jobber for details. I strongly suggest first purchasing the smallest possible quantity in an attempt to verify the proper shade. Custom mixed colors are not returnable. Unfortunately, whenever a color proper name has multiple codes listed against it, I have no idea which one is appropriate for your application. If you are particular about shade, you may have to sample them all. If you wish to get information on the different chemistries available from PPG, including technical data sheets (detailed usage info) and material safety data sheets (MSDS=safety & health info), go to the PPG website." Oliver Clover White (1959)----- ----- ----- 8229 Oliver Clover White (1959)----- ----- ----- 8805 Oliver Cletrac Orange----- ----- ----- -----60583 Oliver Equipment Dark Charcoal---- ----- ---33768 Oliver Equipment Dark Charcoal----- ----- --34347 Oliver Equipment Dark Charcoal #90833----- -33194 Oliver Equipment Green (1959)----- ----- ---42638 Oliver Equipment Silver Poly (Met.) #90832--8960 Oliver Equipment Green (1959)----- ----- ---41223 Oliver Green----- ----- ----- ----- ----- --45132 Oliver Green----- ----- ----- ----- ----- --40249 Oliver Green----- ----- ----- ----- ----- --40812 Oliver Industrial Yellow (1959)----- ----- -81154 Oliver Industrial Yellow (1959)----- ----- -82335 Oliver Orange----- ----- ----- ----- ----- -60433 Oliver Yellow----- ----- ----- ----- ----- -81892
