wheeled platform to put tractor on
tractorhank
11-19-2007 17:12:30
I am looking for a 4 wheeled rollabout platform or dolly that I can put a small to medium tractor on for painting without the wheels on the tractor. I have to paint outside, but want to be able to roll the tractor back inside without the wheels on it afterwards so that I can assemble it. Any ideas if somebody makes something like this or am I going to have to have it built. I would like adjustable stands on it to fit under tractor frame and axles. 785-748-0061
jd b puller
12-17-2007 18:02:47
 Re: wheeled platform to put tractor on in reply to tractorhank, 11-19-2007 17:12:30
Hank, if you're going to stay on a concrete floor... I bought a 2 TON Engine hoist at Northern Tool. That's enough to pick the whole tractor (JD B) up off the ground. Put Eye hooks in the axle and a hook in the frame and have at it.
Good luck
David Maddux
12-17-2007 15:21:09
I have been thinking of using a wagon gear and frame to do this with. Would have to make some changes where you actually hook up to tractor, but it is an idea.
Jsokol
12-03-2007 16:36:21
First time actualy replying to a post, I did all the paint work in our warehouse and used heavy duty 4 way pallets stacked underneath with shim boards to support and took the wheels off then had an entirely mobile setup with out the wheels. Would work great if you had a paved surface or concrete and had a pallet jack. Can pick up cheap pallet jacks from northern. Aslo handy for positioning heavy wheel tire combos for remounting even the biggest ones. Good luck
wayneh
12-01-2007 15:06:11
Funny you ask about that, I just made one for my B. If I knew how to post a picture of it I would, but I used 3" sqaure stock 3/16" and welded a big square with 4 very heavy duty casters. The I welded some vertical parts to attach to the back axle housing.
Wayne
GlenIdaho
11-19-2007 19:40:37
Hank; You might check out Northern Tool.com. They have dollies for autos. There are several different types. I bought four that I use under the lift arm assembly of my loader. As you, to move it around while making repairs and painting. Be sure to check the weigh capacity. Hope this helps...
