painted tires
garys vao
12-13-2007 06:44:13
how can i remove overspray from my rubber tires? i'm inside the garage now, with wood heat, cause of the cold here in Mi.. i know gas will take some off,but there's got to be something better. i know i should have covered them, but that's water under the bridge. thanx gary
tommyw-5088
12-28-2007 08:49:06
 Re: painted tires in reply to garys vao, 12-13-2007 06:44:13
you dont need the tire paint ,just use any alkyd enamel .
alkyd black is all i use ,it will stay on for years
Damp;Dservice
12-14-2007 16:53:51
zip strip chemical paint remover and a wire brush, mask off the rim and brush on some paint stripper, let set, use a wire brush to pull paint from tire and wipe off, then wash with dawn and hot water, works great for me all the time, especialy on checked or old tires.
5020s rock
12-14-2007 14:00:45
hi--i will tell you what doesnt work-lol.
i tried gas, laq. thinner and mek (methyl ethl
ketone from my work, where we paint steel with
rubber rolls). i am leaning towards that tire paint from miller, people says its good. ok--now we will get the tire stain on the yellow rims,
right-lol
Kent in KC
12-14-2007 06:58:18
Before you paint, smear a thin coat of vaseline on the rubber, overspray will wipe off. For your dry overspray, I agree with lacquer thinner. However, before you paint your tires with tire paint, try cleaning them with Scrubbing Bubbles bathtub cleaner. In one minute you'll be amazed at how clean the rubber looks. I'd also follow up with a good tire treatment like Meguiars, wipe off the excess.
circus
12-13-2007 20:13:39
Lacquer thinner
8N'r--WI
12-13-2007 12:23:21
1)plastic scrub brush with liquid dish washing detergent
2)paint the tires with black tire paint from Miller Tire in Ohio (on ebay as well)
the tire paint will make your tires look like brand new tires----used it on some restoration projects.
Tim
