painting ?s
noidea
12-21-2007 20:14:44
How cold can the air temperature be to still be able to paint a tractor nicely? I dont have a heated shop. Am I just going to have to wait to spring?
Kent in KC
12-23-2007 06:36:19
 Re: painting ?s in reply to noidea, 12-21-2007 20:14:44
Warning! Warning! Beep! Beep!
Don't paint your tractor then light a space heater. You will get unexpected results. Like an explosion, only bigger.
patsdeere
12-23-2007 12:31:06
 Re: painting ?s in reply to Kent in KC, 12-23-2007 06:36:19
I may have been born at night, but it wasn't last night.
I have an electric space heater. I usually allow an hour or two to pass before I even turn it on.
patsdeere
12-23-2007 00:28:08
I have used a low temp reducer and it turned out quite nice. I actually prefer it over the high temp since it dries a little faster. After I get done shooting I throw a space heater in the area for a little while and poof. It can be handled in a couple of hours (carefully). After a day or so it is hard enough to move, but watch the fingerprints.
I don't know if I just got lucky with the paint job or what, but had 1 run that after tilting the piece it went away. Just my $.02.
smdv806
12-23-2007 10:15:43
 Re: painting ?s in reply to patsdeere, 12-23-2007 00:28:08
Just how cold can I paint with the reducer?
glennster
12-23-2007 14:02:05
 Re: painting ?s in reply to smdv806, 12-23-2007 10:15:43
i wouldnt go below 65 degrees. after you are done with the last coat, you are going to need to maintain temperature for quite a while so the paint can flash off and start to dry, if its too cold, the paint will stay tacky and pick up all kinds of dust. then there is a lot of wet sanding and buffing. to get a nice finish and good shine to the paint, i like to put my last coat on very wet, almost to the verge of running it but not quite. i also like to use a hardener. heres a couple pics of an h grille and tank in napa's crossfire with hardener, very wet final coat.
third party image
third party image
and here is my cub, this one has good old farm and fleet alkyd enamel with hardener.
third party image
GlenIdaho
12-22-2007 15:36:48
Hello again; had an after thought. Whatever paint you use, get the spec sheet for it and it should tell you the temps recommended.
GlenIdaho
12-22-2007 13:08:20
Hi noidea; I'm in the same spot. Just too cold to paint, so I'm waiting for spring too.
glennster
12-22-2007 04:49:10
i dont like to paint below 70 degrees. you can get reducers for your paint that are designed for the 60 degree range. however they are a very fast evaporating product to get the paint to flash off in the colder temps to avoid sags and runs and to speed drying in colder temps.
