Ford Red
01-12-2008 12:07:48
Re: Thinking about paint durability in reply to D.P.N, 01-10-2008 18:20:31
Sherwin Williams Tile Clad is an epoxy product. Epoxy is tough and has good chemical resistance, but sunlight causes it to deteriorate. That"s why epoxy isn"t used to paint cars. For best results I recomend that you use a urethane enamel. Although epoxy is resistant to more chemicals than urethane, urethane is not damaged by exposure to fuels, oils, brake fluid, alcohol, and most solvents. Urethane is tough and durable, it is used to paint locomotives, aircraft, water towers, dump trucks, and industrial machinery & equipment. Down sides.....even the industrial grades should be applied over primer; if sprayed, proper breathing protection is needed; and like epoxy, good urethane isn"t cheap. I have found the industrial urethanes tend to be somewhat less durable than the more expensive formulations, and they don"t cure as glossy. But on the up side they are cheaper, easier to apply, and go on heavier.
