Painting an engine
Scott Rukke
01-13-2008 11:20:37
I am restoring my F-20 and was wondering about how to go about painting the engine. I want to primer it with everything else and spray all at once but am unsure if I need high heat paint or even if the primer will burn off. I am not using epoxy paint or primer.
CNKS
01-13-2008 11:38:38
 Re: Painting an engine in reply to Scott Rukke, 01-13-2008 11:20:37
The primer and paint will only burn off the manifold, so high temperature paint is not needed, but I strongly advise you to use epoxy primer (not paint). It gives better adhesion to both the metal and the overlying layer than any other primer.
