painting in the cold
loneranger27
01-15-2008 16:28:39
HI everyone,
I have a basket case 1030 that I have been rebuilding and putting back together and I have everything on the motor done and i want to paint all of the external part before i put them on so i do not have to take it all apart when i finally paint the whole tractor. I have read on here that a few have used torpedo heaters to heat it warm enought to paint but said they got an OK paint job. I am considering this as I live in southern illinois and it wont be warm enough to paint for a couple months and I dont want to wait that long to put the engine together. Am i making a mistake?? Your input is appreciated. I really only care about the parts being orange no cracked paint.
PhilC
01-27-2008 17:51:17
 Re: painting in the cold in reply to loneranger27, 01-15-2008 16:28:39
rustyj said: I tried painting some toy tractor parts in my garage that was heated by a torpedo heater and what did i get??? FISH-EYES!! BIG FISHEYES!
Wasn't a kerosene torpedo heater was it? :mrgreen:
rustyj
01-27-2008 11:25:45
Mike S 806/H
01-23-2008 12:47:28
I painted my Farmall 450 engine in freezing weather it was caseih paint with med reducer, engine was bare metal and just wanted some paint on it, after spraying out side I put in the shop about 45 in there, took about 5 days to dry enough to handle , has been 3 years now and looks great,
soundguy
01-21-2008 12:36:53
I agree with CNKS.. temp is important.. so is humidity.
The last tractor i painted.. some days were cool.. the days that were int e 60's.. i painted at 68'.. and I was worried that it was not going to turn out as well.. so i only did cast parts.. i waited till 70's temps and up for the tinwork..
Some of the test shots i made that morning on scrap tin in the mid 60's was not turning out well.
soundguy
PhilC
01-18-2008 20:58:18
It can be done down to about 60, but no lower unless you want all the problems glennster mentioned. You must match reducer and catalyst to the temp or your efforts, and paint, will be wasted. This goes for very hot temperatures too!
The shop I work at doesn't have a heated air make-up booth (glad I'm the bodyman) so we deal with this all the time from late Oct - May. It sucks (no pun intended) to have to rely on shop heat to paint with, but we get it done every day and turn out quality work too.
The hardest part will be getting the temp to a useable zone, and keeping it there long enough to paint. Once you turn your heat off, the temp will start dropping quickly, even more so if you have an exhaust system (you're not painting without one right?) and limited to no insulation in your shop.
jd b puller said: CNKS, you said, absolute minimum of 65*. What if it's not that warm? Will it just take longer for the paint to dry, or will the finish suffer? Durability, etc.
Then you should not paint, because the paint won't dry (it won't cure either) and the finish will suffer. You nailed it - no durability.
CNKS
01-15-2008 17:59:43
You do not want a flame or spark from any source if there are paint fumes in the area. You can use the heater, but shut it off before you begin to paint, and don't relight it until all fumes are gone. You need an absolute minimum of 65 degrees when you paint and for several hours afterward as the paint dries. Depends on what you call "OK".
jd b puller
01-16-2008 13:49:28
 Re: painting in the cold in reply to CNKS, 01-15-2008 17:59:43
CNKS, you said, absolute minimum of 65*. What if it's not that warm? Will it just take longer for the paint to dry, or will the finish suffer? Durability, etc. Thanks,
glennster
01-16-2008 14:32:31
 Re: painting in the cold in reply to jd b puller, 01-16-2008 13:49:28
depending on the paint, but, the solvents will not flash off correctly if your temperature is not in the range for the reducer. you can run in to adhesion problems, and if the reducer is too "hot" ie slow to flash, it could bite in and start to dissolve the primer coats and possibly body fillers. then you run into the problem with dust and dirt getting in the wet paint before it sets. last, if its too cold, it wont set quick enough and you will get sags and runs.
61-4010
01-16-2008 11:41:55
What about using a oil radiator type heating. Those are sealed....so they should work for heating purposes. Yes?
CNKS
01-16-2008 12:15:59
 Re: painting in the cold in reply to 61-4010, 01-16-2008 11:41:55
I suppose -- we have a small one (1500 watts) in our laundry room, it has no visible elements. Had a furnace breakdown earlier this year and used it in the main part of the house. It would take a very large one to heat an area of any size. Also very expensive to operate in a large area. I have a 48000 BTU overhead natural gas furnace in my shop (30x30 work area), I simply turn it off when painting. But, I have explosion proof exhaust fans that I run when painting, they will evacuate the area rapidly, and lower the temperature about as fast. There is no real good answer for painting in freezing temperatures.
