Painting Farmall M
Erics Farmall M
01-21-2008 12:02:47
Goody Question Going To be Painting A Farmall M And Only Have A Regular MAchine Shed Or Outside To Do It What Is The Best And Simple Primer To Use And What Paint Should I Use? Should I Put A Trap Down In Shed And Paint It Inside Or Should I Paint Outside When Weather Is Nice And Decent?
Andy Motteberg
01-25-2008 21:47:53
 Re: Painting Farmall M in reply to Erics Farmall M, 01-21-2008 12:02:47
I painted my H outside because I don't have a garage!
soundguy
01-21-2008 12:26:29
I paint outside where i can get ventilation.
If you have lots of dust.. you might spray an area down and / or put a dropcloth down.. and even put up temp sheeting for a booth.. up to you. All depends on your environment.
use a primer made to be compatible with your intended paint brand and chemistry.
You want 500$ paint that will look like a car job.. and hold up good in the uv with little care.. or you want 65$ paint that can last for years with some care and a wash and wax job every now and then.. ( keep under cover to make finish last longer ). You can get either or.. or anything inbetween and ++++$$$$
If it a work tractor.. I'd just as soon scratch off 65$ paint on twigs and branches and rocks.. than scratch off 500$ paint.
3 good weeks of brush pile work will make each tractor look the same..
soundguy
