New Holland Baler Paint
Nathan Kapp
01-25-2008 19:28:57
Hello all, I have a model 65 new holland square baler that I am planning on repainting in the spring. What type of paint should i use. Im concerned that an enamel paint will fade easily while in the field - esp since it is red. Any suggestions? I don"t feel a base coat/clear coat would be applicable here, but enlighten me.
CNKS
01-26-2008 17:40:22
 Re: New Holland Baler Paint in reply to Nathan Kapp, 01-25-2008 19:28:57
You are thinking about alkyd enamel, a cheap paint that will fade outdoors. Acrylic enamel and, in particular acrylic urethane fade much more slowly.
Nathan Kapp
01-27-2008 19:44:20
 Re: New Holland Baler Paint in reply to CNKS, 01-26-2008 17:40:22
Yea, the alkyd enamel was what I was concerned about. Is the acrylic enamel what you would recommend using for this application? Thanks for your help.
nate
