OT/ 99 Olds -Glennster
Maark
01-29-2008 12:48:28
My daughter hit a Deer with her Cutlass. I need to replace the top radiator support. Do you have the measurements from the firewall to the radiator support. I want to get it back in place before I cut it loose. Thanks, Mark..
Maark
01-29-2008 16:20:23
 Re: OT/ 99 Olds -Glennster in reply to Maark, 01-29-2008 12:48:28
Thanks, She hit that Doe right square in the middle. Only the tie bar pushed back. fenders are undamaged, headlights aren't broken. will replace the hood and tiebar, header panel along with the bumper cover. Radiator still hold antifreeze and the ac still works.
glennster
01-29-2008 13:36:48
here ya go!!!!!
third party image
glennster
01-29-2008 13:48:59
 Re: OT/ 99 Olds -Glennster in reply to glennster, 01-29-2008 13:36:48
the tie bar is going to weld in and your big control points are on either side at the front fender front bolts. take measurements from the strut tower bolts as indicated. once the two corner points are correct, as long as the strut towers havent moved back, you should be good to go. pre fit the tie bar, anchor it with self tapping screws before welding. i fit the fenders and hood at this time also to be sure everything is correct. hood striker should line up too. if not, recheck everything. the measurements need to be within 3 mm. there is not a lot of wiggle room after its all welded together.
