Re: painting glavanized metal.
B. L. Taylor
02-14-2008 11:15:23
If you have a PPG or Dupont paint supplier, or Valspar for that matter, they make an epoxy primer/sealer that is a "self etching" or non sanding primer which is used on automotive applications. (I don't know much about Valspar though.) The metal does have to be cleaned and prepaired though. The guys at the paint store can tell you for sure if it can be used on galvanized metal and will assist with further details. I'm sure that it will work though. I have a Ford Econoline pickup which is apparently galvanized and I intend to use it on that vehicle. I use it on everything where the metal is bare.
