plagiarized from highway comission
Circus
02-19-2008 04:06:58
Performance Experience: Recent and ongoing FHWA-sponsored test programs have found that coating systems employing zinc-rich primers have performed very well as a generic class, even in harsh marine and salt-rich environments when applied over blast-cleaned steel (SSPC SP-10 or SP-5). Three-coat systems such as solvent borne inorganic zinc or organic zinc primer/ epoxy intermediate/ urethane topcoat, have shown performance far superior to all other conventional coatings (without zinc-rich primers) tested in parallel to-date under harsh exposure conditions. The primary performance difference between zinc-rich coating systems and systems based on barrier or inhibitive protection is the resistance to disbondment and underfilm corrosion at holidays or defects in paint films and at corners and edges of structural steel members. Performance of inorganic zinc-rich coating systems has been particularly good in various test programs.1, 2, 3 Organic zinc-rich systems have also performed well over blast-cleaned surfaces, as long as the zinc pigment concentration in the formulation has been sufficient to ensure conductivity of the primer.4, 5 Many formulations are marketed as organic “zinc-rich” with low levels of zinc pigment. These formulations would not be expected to perform better than a similar barrier coating system without the zinc pigment.
GeneMO
02-19-2008 20:01:32
 Re: plagiarized from highway comission in reply to Circus, 02-19-2008 04:06:58
Hmmmmm, dont think we are going to be able to find this stuff in a rattle can huh?
circus
02-20-2008 03:17:20
 Re: plagiarized from highway comission in reply to GeneMO, 02-19-2008 20:01:32
Spraybomb is probably the only way you will find zinc-rich coating. Rustolium zinc-cele and other brands. I've seen it in most hardware stores.
