Buffing a paint job
Hacksaw
06-12-2002 12:23:35
Just got done painting some pieces that aren't as smooth and shiny as I'd like them to be.Can I buff them somehow?Or do I color sand them or what?Thanks!
Truck
06-20-2002 07:38:11
 Re: Buffing a paint job in reply to Hacksaw, 06-12-2002 12:23:35
ALlow them to fully dry so you can't smell any solvents escaping from the surface.
Then try buffing first. If that won't do it, try color sanding with 1200 grit, wet, then buffing.
If it still isn't good enough, use 600 grit then 1200, then buff.
I'm assuming it is a solid color. Metallics don't color sand well. Nomally if you plan on color sanding a metallic you would cover it with a clear that would be sanded.
None of the above will work on castings. Color sanding is for sheet metal and other smooth parts.
Clooney
06-13-2002 09:28:59
Hacksaw, we have to know what brand & type of paint you used & if you used hardener in the paint before we can advise you on the rubbing or sanding procedure.
Hacksaw
06-13-2002 13:01:44
 Re: Re: Buffing a paint job in reply to Clooney, 06-13-2002 09:28:59
Hey Clooney, I used NAPA acrylic enamel with hardener. hope that helps. thanks. -Hacksaw
Hacksaw
06-13-2002 13:00:38
Hacksaw
06-13-2002 13:00:36
Hacksaw
06-13-2002 12:57:43
Hacksaw
06-13-2002 12:57:16
