Sanding primer
Learning2Pull
03-16-2008 03:37:01
In the process of painting my Farmall M, primed the hood and have a couple particles (gnats possibly) and was wondering if I could sand with like a 1200 grit or something (wet sand possibly) before I shot it with the final coats of paint. Any help is greatly appreciated!
Maark
03-19-2008 07:16:03
 Re: Sanding primer in reply to Learning2Pull, 03-16-2008 03:37:01
If you haven't already done it, primer on sheetmetal needs to be wetsanded for better bonding or adhesion, also removes the little blemishes you described. I use 400 wet and dry, wipe or blow dry. Be sure to use a tack rag on the metal to remove any dust bugs or remains from sanding.
circus
03-16-2008 08:12:29
No need for 1200. 400 is fine enough for primer. If gooy like epoxy a little mineral spirits and DA paper doesn't clog but will dry out hands. Allow to dry and remove any film prior to topcoat.
jose bagge
03-16-2008 04:03:05
try a real fine 3M pad....
