Info For CNKS and others
Dick L
03-25-2008 10:58:15
Checked Walmart and most of the measuring cups/spoons are polypropylenes. I didn't see any polystyrene ones. That was what they used to be made of.
If you look on the handles you will see the recycle symbol with the letters under them. (posted at the link) PP for polypropylene which paint or thinners will not degrade. The PS stands for the polystyrene which will degrade in paint and thinners.
Years ago I was involved in gluing two polystyrene half parts together. We dipped the parts in Acetone and clamped them together.
I also was involved in putting two polypropylene parts together and that had to be done with heat to melt the edge of each half and quickly pressing them together.
I made hospital wash basins out of polypropylene and high density polyethylene as well as auto oil drain pans. I still have basins around and use them to wash parts in thinners and gas.
dr sportster
03-28-2008 07:30:46
 Re: Info For CNKS and others in reply to Dick L, 03-25-2008 10:58:15
Dick, What type are called PEP.That is the type recommended by One -Shot signpainters paint.The wrong type will leach into the paint.They sell little squeeze bottles to keep the paint in but I would like to be able to ID them in the supermarket[maybe cheaper than the paint supplier]Thanks good info.
Dick L
03-28-2008 08:38:08
 Re: Info For CNKS and others in reply to dr sportster, 03-28-2008 07:30:46
P-E-P is a plastic manufacturer that sells a variety of consumer products using a variety of different types of plastic. It stands for Plastics Engineered Products.
If it would be an actual plastic material you would see it in the symbols. A lot of, but not every comsumer product has the recycle symbols.
RobertTX
03-26-2008 07:54:20
For mixing, the paint jobbers have nice mixing cups, they are cheap or free if you buy much from them. For dipping the little cups from the individual Jello servings are great. Just the right size and they are paint and solvent resistant. You can even clean and re use them.
CNKS
03-26-2008 06:58:30
Thanks for the info -- But for measuring spoons I use metal. Most of my mixing is done in 8 oz plastic cups designed for the purpose bought at the paint store. For larger quantities I use glass -- that way I don't have to determine the type of plastic.
Dick L
03-26-2008 09:10:41
 Re: Info For CNKS and others in reply to CNKS, 03-26-2008 06:58:30
Having my own plastic factory for 32 years I have had to fight the miss understanding and and incorrect rumors of the different materials buy not only potential customer but employees as well. I would never expect you or anyone else to change a thing you are doing or using. Just stating there is proper materials for a use and there is improper materials that will not work for a particular use. I was only trying to replace an opinion with facts.
CNKS
03-26-2008 17:17:35
 Re: Info For CNKS and others in reply to Dick L, 03-26-2008 09:10:41
That's fine. I know through experience that there are differences in plastics when it comes to resistance to solvents. I simply stay away from them unless they come from a paint supplier. That way I don't have to figure out what will work and what will not.
