painting help
MTA farm
04-10-2008 11:28:33
Was talking with a buddy of mine. He has painted a car before. I am going to do the same process he did. First prime then wet with 500 grit. Paint the color you want then add clear coat. Wet sand again with 2000 grit. Then use rubbing compund afterwards. when he wet sands uses dawn soap thats fairly warm. His car turned out good. Does this seem like a good process to you guys?
Circus
04-10-2008 15:33:47
 Re: painting help in reply to MTA farm, 04-10-2008 11:28:33
Clear is useful for metalics, for straight color it's unnessary. I wonder if your friends is sanding a polishing because of flaws in the gun finish? It does give a flawless finish but is alot of work and it's tricky polishing nocks and cranies plus swirl marks. Only do it if the finish from the gun is unsatisfactory. I'dd use the highest quality materials available. Much less work and lasting results. Good luck.
