Lets see
Lanse
04-13-2008 15:21:25
if i got this right. So when i paint my B, ( i told ya i would wait till it ran, and i will, dont worry)
Then i should do as follows
1)use paint stripper and wire wheel on angle grinder to remove all signs of crappy brush job, down to bare metal
2)spray primer (same brand as paint), let dry, sand, spray again, let dry again, sand again, spray again, let dry again, sand again (all with 200 grit and sanding block)
3)spray on paint, let dry, spray again, let dry, spray one last time
However, i decided to use hardener this time, where would i get it, how much is it, and how much do i put in a gallon of paint???
I'd like to get ready spray this on, less mixing things. I'm also planning on using a cheap spray gun from Harbor freight. I cant justify a $400 gun for a $450 tractor-i just cant. I decided to ask stupid questions instead of screwing something up (again) :-)
Jim Voyles
04-17-2008 02:56:11
 Re: Lets see in reply to Lanse, 04-13-2008 15:21:25
Lanse, follow up on your questions. You can get hardner at auto stores that sell paint. O'Reilly's, Napa, etc. Fairly expensive. Follow the directions on the can for amount to add.
Jim Voyles
04-14-2008 03:53:12
Lanse, these are not stupid questions. Sounds like you have it about right. Be careful with the paint and breathing the fumes. Hardner and new paints have fumes that can kill you. you will need a fresh air supply breather mask to be safe.
Lanse
04-16-2008 17:55:48
 Re: Lets see in reply to Jim Voyles, 04-14-2008 03:53:12
will do, thanks jim!!!
