Fender Repair
Sean (TX)
04-17-2008 17:04:29
I have some really rusted out fenders on a 2N. What is the best way to braze up the holes? Would it better to use a patch? Slow going trying to fill them..
charles todd
04-25-2008 22:34:22
 Re: Fender Repair in reply to Sean (TX), 04-17-2008 17:04:29
Unless you are going for "brass fenders", I would replace them. Even import reproduction fenders will be better than those repaired. Even if you repair them, grind them smooth, prime and paint, rust will show its ugly head eventually. Rust is the devil.
Sean McDonnell
04-25-2008 15:28:34
I'm normally all for trying to save as many original parts as you can. After seeing the pics of your fender skins I think I would go with replacements if I were you.
Sean (TX)
04-20-2008 16:49:23
 Thanks in reply to Sean (TX), 04-17-2008 17:04:29
Thanks...I may look for better used ones. The hood and dog legs are in the ssame condition if not worse...
mrbillsmolines
04-18-2008 20:06:17
You can buy new fender skins for around 60.00
Call Tractor Parts Shed 573-864-3475
Sean (TX)
04-17-2008 17:48:13
 Re: Fender Repair in reply to David Schupbach, 04-17-2008 17:04:29
I may have to rent one.. Here is what I am up against...
third party image
third party image
third party image
glennster
04-17-2008 17:42:54
if at all possible, cut out the rusted areas and weld in new sheet metal. if you have a mig welder its a lot easier. if all you have access to is a brazing torch, it can be done, you have to take your time any try not to overheat the panels so they warp.if you are doing bodywork over the brazed areas, use a fiberglass reinforced filler as your first coat over the brass, not bondo, bondo will not stick well to brass. here is a link to the product, or any similiar from napa or your nearest auto body supplier
B-maniac
04-19-2008 20:17:04
 Re: Fender Repair in reply to glennster, 04-17-2008 17:42:54
With all due respect , a good body man could fix these but a smart body man would replace them! They are too far gone and there are too many good alternatives to try repairing them.
rustyj
04-20-2008 10:35:46
 Re: Fender Repair in reply to B-maniac, 04-19-2008 20:17:04
I'll go along with that--too far gone to fix-way too far! And, if ya get one side repaired, then what about the other side? (Thats inner and outer!?! Fixing car fenders was done that way, because ya couldn't usually see the inside of them, but a 2 sided tractor fender is a whole new ball-game. You'll spend $400 to fix them, where ya can buy new ones for $60? MMM-HMMM! What was it that old P.T.Barnum said?
