paint
bob 55
04-22-2008 07:22:22
I was wondering if anyone knew about how much primer and paint i would need to get to paint a Farmall M. And about how much it might cost? Thanks for any replys
CNKS
04-22-2008 17:35:47
 Re: paint in reply to bob 55, 04-22-2008 07:22:22
$40-$400. Minimum 5 quarts if you don't disassemble. If you do it right and take everthing off and paint separately probably 7-8 quarts -- this is an estimate as the largest tractor I have painted is a Super H. It took about 1.5 gal, if I remember right, all parts painted separately. Case-IH 2150, I think is about $45/gallon, and is the cheapest paint that will do a lasting job. The farm store stuff is about half that and will fade rapidly on a tractor left outdoors. PPG Omni/DuPont Nason, the next step up will be about $130+ for paint, hardener, and reducer. You add to that the cost of primers, surfacers, etc. Cost goes up from there. All depends on what kind of a job you want.
patsdeere
04-22-2008 09:48:19
I don't know the volume, but the cost will depend on what brand paint you use (omni, Dupont, Napa) and then the high cost or low cost versions of each.
