sand blasting
GI FARMER
04-24-2008 07:31:15
was wanting to buy a small 80-110 LBS. sandblaster one of those cheaper ones from like harbor freight and wanted to know if anyone ever used one and if the were worth a darn? I just want to clean up some of my old junk and repaint it. I painted an old brush hog with RUSTOLEM paint I used a roller and a brush I put it on pretty heavy that was 2 years ago and it still looks good.any tips or advice would be great. thanks
GlenIdaho
04-25-2008 05:24:51
 Re: sand blasting in reply to GI FARMER, 04-24-2008 07:31:15
I have the 110 lb model from HF and it works well. I found that using 70 grit sand works the best. Anything heavier clogs the lines. As was stated by Circus and CNKS, the compressor is the important factor. I wore out one compressor using the sandblaster. They are a slick way to clean metal. Also, make sure you have the proper respiratory protection. The silica will damage your lungs.
circus
04-25-2008 03:17:57
All pressure sandblasters are much the same. The compresser determines performance.
CNKS
04-24-2008 17:09:57
They are ok, but they use a lot of air and are very slow. My air compressor puts out 24 cfm. I get the job done, but it is slow on large parts such as 38 inch wheels. My compressor does not have a 100% duty cycle, but I run out of sand at about the right time, so it gets to cool off a little. I would hate to use it all day like that.
