Best way to mask off decals
Mike M (RI)
06-19-2002 14:38:56
I want to re-paint my 1968 Wheelhorse Raider 12 lawn tractor and the decals on the sides of the hood are no longer available from the dealer. How do I mask off the old decals? Do I use masking tape & trim around them with razor blade, or is there a better way of going about it?
Mike C. (MA)
06-20-2002 08:06:38
 Re: Best way to mask off decals in reply to Mike M (RI), 06-19-2002 14:38:56
Mike,
Be carefull if you use masking tape on decals. If left on too long it will bond to the decals and destroy them. You might want to check out liquid mask. Several manufactures make it and if you do a search on "liquid mask" you will get many hits.
Most hobby or craft stores cary it in smaller quanties for the hobbiest. I use it for air brushing and it works wonderfully. You simply paint it on, let it dry and spray over it. After the paint sets up but before it dries completely, lift the edge of it with an exacto knife or razor blade and it will peel right off like a latex glove.
Just make sure you apply it thick enough (6 to 7 mil). The thicker the better and if you get sloppy you can trim off the excess before you paint.
Mike C. (MA)
06-20-2002 08:00:56
Mike,
SOmetimes you can use fine line 1/4 inch tape around the edges ...NT
06-20-2002 07:39:50
