Is there a difference between Reducer and Thiner??
Mark/Ks
06-20-2002 05:08:47
This is probably a dumb question but I hear both terms being used, and wonder what the difference is between reducer and thiner....
Thanks...
Thinner is for Lacquer , Reducer is for enamel...more..
06-20-2002 07:12:17
 Re: Is there a difference between Reducer and Thiner?? in reply to Mark/Ks, 06-20-2002 05:08:47
And you shouldn't try using thinner where reducer is called for , or vica versa, or you may have a spray gun full of curdled paint. It's almost guaranteed when using reducer in lacquer.
I occasionally use VM&P Naptha instead of reducer with hardware store enamels, but when it is cold out I find a fast drying reducer to thin the enamel enought to spray. You can buy reducers that are formulated for fast or medium or slow dry times. This is so you can adjust the drying to the size of the job you are doing and the temperature. If your paint drys too quickly when spraying large objects, you may not get a good blend where you overlap your first pass of the gun and your last. If it dries too slowly, you will get sags and runs or dirt in the paint.
Lacquer thinner I use mainly to clean up spray equipment with. I keep the used stuff in an old thinner can, and keep reusing it. I don't spray much lacquer anymore. Truck
