John Deere primer for CIH 2150?
JW 44
05-08-2008 11:03:17
I just bought a gallon of CIH 2150 Red Rouge and the can has "enamel" on the label, is it the modified version? or not? My local dealer does not have the primer, can I use the John Deere brand? or would it be better to use another brand and a different color primer?
Thanks for any info.
Mike S 806/H
05-08-2008 19:09:36
 Re: John Deere primer for CIH 2150? in reply to JW 44, 05-08-2008 11:03:17
I use JD primer with 2150, with the JD primer you have to wait I think 36 or 48 hours before top coating, other then that JD primer works great
CNKS
05-08-2008 17:27:26
I also noticed that the cans no longer say acrylic modified alkyd enamel. So I do not know if it is again the old unmodified 30's type alkyd enamel. JD cans say alkyd enamel. It is possible that both JD and CaseIH are simply calling the modified version enamel or alkyd enamel?? Although it is best not to mix brands, I would have no hesitation to use the JD primer in your situation. However, epoxy primer is best, adheres better to the metal and the topcoat. Also costs twice as much -- more than the 2150 topcoat.
