Paint/Clearcoat question
oliver77guy
05-17-2008 09:23:55
When I sprayed my tractor, I sprayed it in my make shift booth. I sprayed 6 coats of base and 6 coats of clear. When I sprayed the final coat of clear I have overspray of the clear on some parts that looks like a hazing or frosting. I know this is probably from poor ventilation. The question I have is can I compound the dull out to make it look even? Thanks,
Mark from WI
05-17-2008 18:18:56
 Re: Paint/Clearcoat question in reply to oliver77guy, 05-17-2008 09:23:55
You might be able to sand it and buff it back! My question is: Why 6 coats of clear? I have painted cars professionally for 10 years now and we usally only use 2 coats and that is way more than they put on the at the factory
JDH
05-18-2008 10:28:53
 Re: Paint/Clearcoat question in reply to Mark from WI, 05-17-2008 18:18:56
I don't know. I had plenty and while I was spraying. Ha ha. It was getting good to me I guess. I forgot to mention it looked awesome as soon as I painted it and then I moved on to other hanging parts and I guess the overspray was too much. What kind off compound do you guys recommend?
Elijah
05-17-2008 12:33:24
Maybe you can wet sand it with fine grit paper. If it don't look right after sanding hit it with another coat of clear.
B-maniac
05-20-2008 18:44:12
 Re: Paint/Clearcoat question in reply to Elijah, 05-17-2008 12:33:24
So who really painted this tractor??? JDH or Oliver77guy??? You have GOT to get the fog out when useing a quick flashing clear coat. You will just have to experiment as to whether to hand rub/sand and buff etc. Hard to machine buff smaller parts. In the future , try clearing fewer parts at a sitting so you don't get the fog. Tractors aren't production work. You have nothing BUT time. Slower IS faster!
