Paint hardner
Mark(Ga)
07-09-2002 17:01:03
I need to know if I add hardner to my paint will it keep the paint good for a long time.I painted my 52 8n in 1999 and now i notice some spots that the paint coming off. Thanks Mark
CNKS
07-09-2002 19:04:30
 Re: paint hardner in reply to Mark(Ga), 07-09-2002 17:01:03
Hardeners help bring out the shine, make the paint dry faster, fade slower, and last longer. It makes repairs easier to make if you mess up an area. Also more resistance to gasoline. Paint chips, if that is what you are refering to is more likely due to lack of surface preparation or some other factor such as incompatible primer and paint, than lack of hardener.
Mark
07-19-2002 10:47:16
 Re: Re: paint hardner in reply to CNKS, 07-09-2002 19:04:30
MAKE SURE if you use a hardener in your paint, that you use some sort of fresh air system to breathe with. Hardeners contain ISOCyanates, which are LETHAL in high enough dosages. For alternatives to expensive fresh air systems, I built a DIY fresh air box out of a bathroom fan, some hardware items and 2 x 4' sheet of 3/4" plywood. I used it last time I painted tractor parts with hardener, and it worked really well. You only get one set of lungs!
Mark
07-19-2002 11:10:35
 Re: Re: Re: paint hardner in reply to Mark, 07-19-2002 10:47:16
Sorry about that, the browser kept saying Server not found, instead of saying it was posted.
Mark
07-19-2002 10:29:29
Mark
07-19-2002 10:28:07
