Questions about rust sealer, primer, and enamel paint matching
RB
07-11-2002 21:30:00
I found a product called RUSTBOND PENETRATING SEALER by CARBOLINE at a Porter Paint store. It is an epoxy which can be applied to a painted surface with rust problems. It says that it serves as its own primer and can be topcoated with your paint. The paint store could not tell me definitely if this RUSTBOND would be completely compatable with Martin Senour paint (from NAPA which I plan to use) , but he was pretty sure it would. Have any of you used this product? Did you prime it anyway? If so, what brand of primer ?
Don LC
07-18-2002 05:32:58
 Re: Questions about rust sealer, primer, and enamel paint matching in reply to RB, 07-11-2002 21:30:00
You don't seem to be getting the responces you need.....If it were me I would use a primer!!The primer will bond the paint to the sealer and give you a scratch filler that you can wet sand, reapply and sand until you have the smouth finished base you want,to put your paint over.....
