Sheet metal prep
Wally
07-18-2002 21:06:29
I'm ready to start working on the hood and grille for my JD A, and I was wondering about the best way to clean off the paint. I don't have a blaster, I heard that can be bad sometimes anyway. Should I strip the paint down and sand the hood, or can I use a grinder and wire brush. Will this hurt the surface from looking good when its done? Also what kind of primer should I use? How about on the inside of the hood, should I clean that and paint it flat black or just like the hood? Sorry for all the questions, its my first tractor, I want to learn to do it right. Thanks in advance.
Bill Hires
07-19-2002 04:55:05
 Re: Sheet metal prep in reply to Wally, 07-18-2002 21:06:29
Done correctly sand-blasting is the best way to remove old paint, especially on the grills and grill screens. There are many good paint removers available, I am using one called Bix on a 39 "B" John Deere hood now and will finish by sand-blasting it. Aircraft paint removers do a good job, also. Power wire brushing and high speed sanders are useful, also. Remember these old paints were lead based and you should wear a dust mask. I prepare and paint the underside of the hood just the same as the rest of the tractor.
