Grille Screen Repair/Replacement
Wally
07-21-2002 11:29:39
Workin on my JD Model A grilles and was wondering about removal and replacment of the grille screens. They are pretty torn up. A couple of the ribs on the grille need to be straightened and I was figuring that removing the grille screens would make the rib work easier. They need to be changed anyway. My question is whats a good way to get them off, grinding? And putting new ones in, would JB weld do the trick? Thanks in advance.
Bill Hires
07-21-2002 13:55:37
 Re: Grille Screen Repair/Replacement in reply to Wally, 07-21-2002 11:29:39
I use a sharp thin chisel and a lot of elbow grease! You might be able to get a small grinder to some of the spot welds. This is not very easy! I drill small holes in the new screens and spot weld them with a Mig welder.
