TOO COLD TO PAINT?
MARK MILLER
10-28-2001 19:03:48
Now that the temperature has begun to dip.
How cold is too cold to paint?
Eric
11-29-2001 03:26:43
 Re: TOO COLD TO PAINT? in reply to MARK MILLER, 10-28-2001 19:03:48
That's all good advice you got on that!
Clooney
11-08-2001 03:45:33
Mark, there are a lot of variables to painting in cold weather, the first being runs, the second being dirt. You can actually paint down in the high 50s but your chance of a run(s) is greatly increased & due to the very long time required between coats dirt becomes a big issue. I have tried to paint in cold weather I have found (at least for me) that anything below 70* is a waste of my time & a waste of good paint. I have had a few good paint jobs in 60* weather but that is the exception not the rule.
slughammer
11-01-2001 09:01:12
One of the things to watch for when painting in colder weather is the lack of humidity. You may think that you need a faster reducer because of the cold; but the opposite may be true. Temperature, humidity and air flow all affect evaporation. The slower the reducer; the flatter the paint will have a chance to sit; up to the point where the speed is too slow and runs occur. Too fast and you'll get orange peel. You can always wet sand and try again.
Bob K
11-01-2001 07:41:46
My paint store guy says not to paint anything below 60 degrees or you'll end up with a dull finish. On primer, that's not so much of a problem, but on topcoat, it's a bummer.
I'm gettting ready to move from painting in the breezeway of the barn to inside the shop where I don't have to heat as much space. Fortunately, I'm far enough along on my restoration that I can roll the tractor out of the shop. Heat is your best friend when painting in the cooler weather.
Gene Davis
10-28-2001 19:54:55
Most paint cans have that info on the label to get the best results.
