Oliver Clover White
kman
08-16-2002 19:52:51
Anyone know of a good match for Oliver Clover White in a spray can? My Agco dealer only has Meadow Green.
Rod (NH)
08-19-2002 17:23:16
 Re: Oliver Clover White in reply to kman, 08-16-2002 19:52:51
Hi kman,
As Jerry B said, you can have an auto paint mixed to the correct color and use a small can of compressed air to spray it. The Preval Sprayer is one such "can of air" that is available at most suppliers to the auto refinishing trades. As I recall, it is only a few dollars. See link below. Also see my post above on PPG paint codes for the Oliver Clover White in that line of paints.
Rod
Jerry B
08-19-2002 09:11:20
Our local Dupont dealer has the ability to mix up a small batch of any color and provide us with a can of "air" that is used to spray the paint.
The paint is mixed somewhat thinner than normal in order for the lower air pressure to propel it.
Your local supplier may be able to fix up something for you.
