Painting rims
ed b
08-20-2002 20:22:15
how do you paint rims with the tires on thanks ed b
Ryan Free
08-25-2002 22:30:40
 Re: painting rims in reply to ed b, 08-20-2002 20:22:15
I masked my tires off around the rim then coverted the tires with news paper. worked pretty good.
Fred
08-28-2002 04:41:28
 Re: Re: painting rims in reply to Ryan Free, 08-25-2002 22:30:40
I mask the tire with wide masking tape at the rim. To work the tape into the groove between the edge of the rim and the rubber I trim the tape with a utility knife to get the fit exact. Then go around the outer edge of the tape with another round of tape to provide protection from overspray. Have had good luck painting the rim while on the tractor. If you mess up and get a little paint on the tire you can wipe 99% off with a rag dampened with gasoline as soon as you finish spraying the rim. Good Luck
nigel jordan
08-22-2002 05:30:26
The easiest way i found when restoring a ferguson tractor, when painting rims if they didn't need shotblasted what i do is clean down as far as necessary then brush on Fairy Liquid (our brand in u.k.) washing up liquid and let it dry. It takes about 1 hour to dry and then you can paint the rims without worrying about overspray on tyres. After the paint has dried all you need to do is was tyres and they will have no paint on them. Try this and let me know.
Nigel
Dave Church
08-27-2002 18:23:29
 Re: Re: painting rims in reply to nigel jordan, 08-22-2002 05:30:26
OK, does anyone know what Fairy Liquid is called in the good old US.
BillD
08-21-2002 07:43:19
In the past I have deflated the tires and used a flat tool to work plastic sheet between the rim and the tire
ed b
08-21-2002 20:42:48
 Re: Re: painting rims in reply to BillD, 08-21-2002 07:43:19
thanks ed b
