Spray paint question.
George
08-23-2002 11:23:20
Don't cringe its just a question: I'm restoring a '48-8N. Mechanically it'll be great but, I'm looking to use it, not show it. I don't have a paint booth or spray equipment and I don't want to pay for a body shop. Could I use a paint like Rustoleum on the castings (not the exhaust manifold of course). Would the engine itself get too hot for a paint like this?
Cliff Bishop
08-27-2002 09:36:59
 Re: Spray paint question. in reply to George, 08-23-2002 11:23:20
I have just completed a similar project with a 300 utility and John I brushed the casting with paint from tractor supply which does not show brush marks on cast metal,then I spray canned the rest,I dont intend to put it in a show but it turned out to be a pretty impressive user
Fred
08-28-2002 04:32:57
 Re: Re: Spray paint question. in reply to Cliff Bishop, 08-27-2002 09:36:59
Cliff, I have completed 2 internationals, a 240 and a 340, now working on a Frod 600; have used aerosol product on the wheels and rims successfully. The chasis and sheet metal I have used TSC paint with my spray gun and it looks good for about a year then dulls. Would hold up better if the tractor was always parked indoors but I use my tractors so appearence is secondary to corrosion protection.
Bill Hires
08-23-2002 15:17:49
Paint the engine with the same paint as you use on the rest of the tractor. The engine does not require a high temperature resistant paint. Use Rust-Oleum Bar-B-Q Black High Heat paint on the manifold, resists heat up to 1,200 degrees.
