Frame question
Jack Feller
08-23-2002 17:44:01
I am restoring a tractor and I am wondering if I should sandblast the frame or what? What would be the best way to get all the old paint off, to make it look like a professional restoration. Thanks.
geoff
09-04-2002 20:41:50
 Re: frame question in reply to Jack Feller, 08-23-2002 17:44:01
buy an angle grinder for $50 and some wire wheels for $8 each, this is what i used on my 140 and it worked great
CNKS
08-24-2002 18:11:25
I'm no expert, but I'll tell you what I'm doing to mine. Removed everything--starter, generator, hydraulics, distributer, etc. Stripped to bare metal using a combination of oven cleaner, pressure washer, paint stripper, and various wire brushes on a 3/8 drill. Going to purchase a sand blaster next time. Keep the sand away from seals and bearings. Sand gets into everything, but is useful for both large areas and small parts. Clean everything with wax and grease remover. Be sure to treat the bare metal with a rust converter. Prime cast with epoxy primer and paint with urethane paint. Same with sheet metal, but will probably use primer surfacer instead of epoxy (epoxy is hard to sand) Since not many people read this board, post your question on the board for your make of tractor for other ideas.
