Plugging Hood Holes
Shep
11-01-2001 06:40:27
I am doing an engine conversion on a Oliver tractor and had to make another hole in the hood to let the air breather come out of, leaving a 4 inch hole in the hood that I would like to cover up and paint over. I could put some sheet metal in the hole and weld it shut but I have seen some of these hole plugs that snap into a hood hole that look real good. I have not seen any that are 4 inches round though. Anyone got any suggestions on where to look for a plug for the hood holes????
Shep Thanks guys
11-04-2001 18:22:20
 Re: Plugging Hood Holes in reply to Shep, 11-01-2001 06:40:27
I think I will try the local airport and see what I can find around their shop, at least that gives me a direction. Thanks again....
big fred
11-01-2001 10:46:35
Sounds like what you want is an "inspection hole cover" used on light aircraft to cover holes in the skin thru which airframe inspections are accomplished.
Bob K
11-02-2001 09:19:05
 Re: Re: Plugging Hood Holes in reply to big fred, 11-01-2001 10:46:35
Big Fred, are you both an aviation enthusiast AND a tractor nut? I am, and someday, I hope to use my old tractor to mow a grass airstrip next to the house. Have to buy the land and get/build an airplane first (details, details). Someday, Lord willing, that dream will become reality!
big fred - sorta
11-02-2001 13:04:28
 Re: Re: Re: Plugging Hood Holes in reply to Bob K, 11-02-2001 09:19:05
I had bought an unfinished Pietenpol Aircamper (1932 homebuilt design, used a Ford Model A engine) from a fellow back in about 1986 and was going finish it and get my license, but ended up selling it when I got married. Flying takes a lot of money, and new regulations in the mid-80's were making it more of a hassle than it was worth. Still like planes, though. Good luck on the airstrip, land, and plane.
Shep.. Yeah, that sounds good!!!
11-01-2001 12:22:24
Where can you get something like that big fred???? The ones I have seen have like little teeth on the back side that hold to the edge of the hole.
Ralph
11-03-2001 19:08:18
 Re: Re: Re: Plugging Hood Holes in reply to Shep.. Yeah, that sounds good!!!, 11-01-2001 12:22:24
Shep: I had 3 Pipers and the inspection plates had a strip of springy medal 3/4 inch wide center riveted to back side to hold it on. The plate was slightly curved like a bowl or saucer and could be snaped bowed in for instalation and then snaped out. Simple once seen and used. They would hold in place fairly well. About 4 or 5 inches wide. Most and small aircraft repair shop should be able to help. ralph
big fred
11-02-2001 07:35:48
Well, my first thought was Aircraft Spruce and Specialty Co, but I couldn't find anything on their website. You might give 'em a try, though, see link for website. A warning, though, airplane parts can be pricey, even worse than JD parts.
