Rust?
TH
09-09-2002 00:07:25
I'm going to paint the hood of my tractor. It is sand blasted to bare metal but there are some rust streaks left in it. The rust is not loose and its very hard (I'm lazy) to remove with sandpaper. What'll happen if I just paint the hood with a little bit of rust in it? Does the rust come through the paint?
Jerry B
09-10-2002 09:26:13
 Re: Rust? in reply to TH, 09-09-2002 00:07:25
If you put a good wet coat of self-etching primer over the entire hood follow by a primer-filler, you should be fine.
