POR-15 again..
Dan
09-12-2002 06:26:54
Would this product work on a soft floor on a car that is 35 yrs.old as opposed to cutting and replacing the floor pan. Not quite ready to go the full resto route yet.Any thoughts?
Duner Wi
09-14-2002 19:20:35
 Re: POR-15 again.. in reply to Dan, 09-12-2002 06:26:54
Degrease and remove the loose rust from the floor boards. I use POR 15 paint directly on fiberglas cloth instead of resin . Make it a few layers thick. If holes are large support the cloth from the bottom via what ever means. Next would be to seal the underside of the floors also. I divide a new QT. of POR 15 into baby food jars . Lasts much better in small containers rather than trying to keep a QT. can half full for any length of tme.
big fred
09-12-2002 14:58:41
I just used a similar product, called "Rust Doctor" on the floorboards of my 1950 Ford F-6 truck. It was rusted thru in several places, and I followed an application of Rust Doctor with several layers of fiberglass, ended up with a pretty strong floor for a lot less expense than replacing the floor pan. Of course, it's impossible to tell how long it will hold, I figure it all depends on the rust converter. It appears to me, though, that Rust Doctor, POR-15 and Eastwood's Corrolless are all pretty much the same animal.
big fred
09-12-2002 14:55:41
Dan
09-13-2002 10:56:22
 Re: Re: POR-15 again.. in reply to big fred, 09-12-2002 14:55:41
Thanks Big Fred, think I'll go for some of that.
Lou
09-15-2002 11:10:57
 Re: Re: Re: POR-15 again.. in reply to Dan, 09-13-2002 10:56:22
We used to use POR-15 but the price was ridiculously high. A friend turned us on to another product that is just as good if not better and costs us $28 a gallon less than POR-15.
