Wheather or not this will work depends on several factors: 1. What brand/type paint was used for the first job. 2. Was it catalized? (hardener added) 3. How long ago was it painted? 4. What brand paint you intend to use. 5. What surface preparation was done previously.If the present paint is activated acylic enamel or single stage urethane, then you should be fine with a another paint job on top. However, synthetic enamel will not lend itself to putting a different type of paint over the top. Hardeners have a tendancey to lift under coats. If the surface of the metal was cleaned with a wire brush to remove the rust, sandblasted or electricaly de-rusted, then the top coats should be tight enough to help resist solvents and hardeners. If there is still rust in the pits, then you are going to have trouble later on down the road. From the way you describe the sheet meatl I am doubting the previous painter took much pains to get a correctly prepaired surface. You could try your approach and see what happens. The worst thing that could happen is that you get to remove your paint as well as the previous paint. Before doing anything I would take a razor blade and shave off the paint in an inconspicuos place to see what is under it. If all looks good then chances are it is good. If you see no self-etching primer with primer filler over that, then you might as well count on stripping it all.
