How to make old paint brighter
rem
09-19-2002 05:14:27
I have a Cockshutt 550 red-belly and the paint is in good condition. How do I get the faded areas not covered with old hard grease back to a darker red. Also, the original decals are in place and I'd like to retain those if possible. Thanks,
Dick L
10-04-2002 17:27:04
 Re: How to make old paint brighter in reply to rem, 09-19-2002 05:14:27
This would be a lot of work on large objects but, I have brought the luster back to antique toys by cleaning them with seelwool, get the area totaly dry, put a light spray of clear enamel on a very small area and buff it off immediately with a soft cloth. Repete untill the whole area has been treated. Do not let the clear enamel dry even a little.
Dick L
10-04-2002 17:26:15
rem
09-22-2002 15:00:31
Thanks to all who responded with helpful hints.
Does anyone have any experience with a product called Color Back? A local dude has indicated that it is good for restoring old paint. Thanks to all again.
Don LC
09-20-2002 17:58:16
Ask around some body shops.....I would wet sand it with 800 0r 1000 grit paper and clear coat it....
Red Raider
09-20-2002 10:57:24
Seems to me you would want to work the finish with mild rubbing compound to the extent it would not wear through to the base metal, avoiding decals.
CNKS
09-19-2002 18:40:31
Same way you would a car. Get an automotive cleaner, then wax it.
CNKS
09-19-2002 18:37:47
