Steve
09-27-2002 17:36:58
One cheap way I have found to get water out of your air lines is to take about 25 ft of 3/8 copper tubing ( or can be larger) attach to the compressor make a coil of the tubing to fit in a 5 gallon bucket bring the end of the tubing out and connect to a water trap with a drain. Fill the bucket with water. The water in the bucket will cool the air and the water will collect in the copper tubing and will fall in the trap as you use the air. This works very well with the small compressors that tend get hot after running for a while. You might want to put one of the little round filters at the gun just for insurance but not necessary. I tried all kind of filters and traps before someone told me about this, it solved my problems.
Gene Davis
09-28-2002 19:21:16
 Re: Tip of the Day in reply to Steve, 09-27-2002 17:36:58
Please over look the extra post!! too much keyboard touching the fingers!
Gene Davis
09-28-2002 19:19:46
We used this method to cool the breathing air supplied under the sandblasting hood in the summer time, put coil of hose in 55 gal barrel with some water running in it, and it felt very good. Poor mans air conditioning!
Gene Davis
09-28-2002 19:19:13
