Paint Condensation Problems
Andrew
10-13-2002 21:30:41
Currently painting sheet metal on a '52 Farmall Super C and getting condensation on painted surface after laquer thinner evaporates. Any suggestions what I should do to avoid condensation?
CNKS
10-14-2002 17:23:01
 Re: Paint Condensation Problems in reply to Andrew, 10-13-2002 21:30:41
If you are using enamel or urethane topcoat, you should be using a reducer, not a thinner. Primers used under such paints are sometimes called laquer primers, however. Are you getting actual water on the surface, or is the surface just rough? If the surface is rough, maybe you don't have the gun adjusted correctly, or there is water in the lines, and you need a better water trap. If you have water on the surface, you have a LOT of water in the lines, or you are painting under very high humidity conditions.
