Repair oil pan
Bill Peets
11-01-2002 03:12:26
No one helped me on my last post of repair oil pan. I took all the dents out but its never perfect how do I smooth out the remaining little rinkles. I normally use body filler but was told not to do this because of the heat generated at the pan from the oil. Is this correct any ideas.
Bill Peets
11-04-2002 04:23:24
 Re: Repair oil pan in reply to Bill Peets, 11-01-2002 03:12:26
Think I will try the body filler. I could always re-do if it does not work. Thanks
redtractorman
11-01-2002 08:29:30
I would think body filler could be used,the oil should not be that hot,or use JB weld that is made to take heat and can be sanded like body filler.
Bill Peets
11-05-2002 02:56:28
 Re: Re: Repair oil pan in reply to redtractorman, 11-01-2002 08:29:30
I will use the body filler thanks for the help.
rhouston
11-04-2002 10:04:23
I agree with the body filler, after all the body of a car can get very hot in the sun. Oil should be approx temp of the coolant unless its an air cooled engine then it is much hotter.
rhouston
11-04-2002 09:59:22
redtractorman
11-01-2002 08:27:55
