Re: Removing overspray
Todd In IL
11-06-2002 12:33:54
you can try using some rubbing compound to remove the overspray. is it enamel/single stage paint? if you are using a spray gun to apply your paint you could use a little thinner or reducer and spray a bit around the area that you are touching up. this will re-melt the paint and blend in your edges taking the dry spot around your spot repair out.
I use a small touch up gun for the reducer and just mist a bit on, enough to get it wet.
