Welding cracks
ff316
11-08-2001 19:21:21
The old brown Farmall H needs a paint job. The hood is cracked on each corner where the latch is located. How should I fix this? My guess would be to first drill a hole at the end of the crack to keep it from spreading, then grind it with a wire wheel, then clamp to realign and weld. Should I weld from the inside where I drill the hole to the edge, or weld from the edge to the inside? Thanks for any advice. Fireman
Tractor man
11-17-2001 19:12:21
 Re: welding cracks in reply to ff316, 11-08-2001 19:21:21
I have mine Sheet meatle and wheels sand blasted before I do any body work. It makes it easyer to weld on. I just take a hammer and a block and straiten them up and weld them. I do mine with a wire welder thougt. Trust me I Do these tractors all the time.
Andy
11-25-2001 11:51:46
 Re: Re: welding cracks in reply to Tractor man, 11-17-2001 19:12:21
If you're cracks are longer than an inch, weld in 1/2 " increments and bounce around and you may have to stop for a bit to keep the sheet metal around it from getting too hot. This helps reduce warping.
