STATION WAGON WOOD GRAIN
jiml
11-19-2002 15:00:47
THIS IS NOT TRACTOR RELATED, BUT CAN ANYONE TELL ME HOW TO REMOVE AND REPLACE THE WOODGRAIN PLASTIC ON A 86 MERCURY COLONY PARK? WHERE CAN I OBTAIN THIS MATERIAL?
carl
11-23-2002 16:28:06
 Re: STATION WAGON WOOD GRAIN in reply to jiml, 11-19-2002 15:00:47
The woodgrain material is still available from an aaftermarket source.Get a copy of Hemmings,look under services;there is a listing under woodgraining for a lady in Oregon. She even had it for my '78 AMC.
monk
11-22-2002 06:18:58
Let me tell you about an old trick used car reconditioners used a few years ago. They would replace the woodgrain with vinyl kitchen shelve liner. Believe it or not, if you got a good grade of the vinyl, it would last several years.
JIML
11-20-2002 15:36:58
Thanks for the info, I was fearful that it would be an ordeal, seems like it will be worse than I thought, with the material no longer avail.
Thanks again
MARK
11-20-2002 10:59:46
i work at a ford dealer the woodgrain adhesive is
not available anymore
MARK
11-20-2002 10:58:38
Jerry B
11-20-2002 09:07:51
My local paint supplier has a remover designed for removing the wood grain adhesive.
As far as replacing it, good luck. These were dealer items only.
jake
12-29-2002 18:53:54
 Re: Re: STATION WAGON WOOD GRAIN in reply to Jerry B, 11-20-2002 09:07:51
3M has a product avalable for removing the woodgrain sheets. I ran across it using the Google search engine and adhesive removers. It's CLR 3M woodgrain & stripe adhesive remover, spray cans and will not hurt paint. I have also seen rolls of wood grain material, if I find will post.
jake
12-29-2002 18:51:55
jake
12-30-2002 19:42:00
 Re: Re: Re: STATION WAGON WOOD GRAIN in reply to jake, 12-29-2002 18:51:55
The woodgrain decal material is available from stripeman.com.
jake
12-30-2002 19:39:26
