To cold to paint?
Bill in TN
11-21-2002 18:45:28
Should get my bushog and front wheels back from the sandblasting shop tomorrow. They've had it 3 weeks! Last pieces and the job is finished! The shop is to prime with epoxy primer. My problem is rain is expected for the next couple of days and temps are expected to be close to 50 or below for the next week. Paint instructions say not to spray below 50. It's my understanding that I have a limited time with epoxy primer. How long do I have and if I have to wait on the weather for a week or more,what will I have to do to get the primer ready to take the paint. Spraying with Dealer paint, acrylic enamel, and hardner, using xylol as thinner. Should I reprime? Wet sand and spray? What should I expect if I spray with temps below 50? What would you do? Any Ideas? Suggestions? Thanks, Bill in TN
Rod (NH)
11-21-2002 21:33:33
 Re: To cold to paint? in reply to Bill in TN, 11-21-2002 18:45:28
Hi Bill,
I suggest you see if you can get the exact manufacturer and product number for the epoxy primer the shop used. My experience has been with two epoxy products from PPG...DPLF and OMNI MP-170. Both of these products have time windows in which they should be topcoated in order to obtain the best adhesion. For example, the DPLF has a maximum seven day window, after which scuff sanding and re-priming with itself is recommended. Similarly, the MP-170 has a 3 day window. I think DuPont's epoxy primer has a 24 hour window but I am not positive since I have never used it. Different manufacturers have different recommended times so it would be best if you could determine the time for the exact product used. If the shop doesn't have the detailed info (they should), if you can determine the exact product, most major automotive paint manufacturers have their technical data sheets available on line. These sheets should give the topcoat window requirement for the primer, if any.
I guess my tendency would be to wait until you get a little warmer weather, especially if you need to recoat the primer anyway...generally that stuff should not be applied below about 60 deg F. The shop primer will provide good protection in the meantime. You should still get a day or two in the 60's in TN even this time of year, no? I understand you would be anxious to complete the project but why push it at this point?
Rod
Bill in TN
11-22-2002 03:41:41
 Re: Re: To cold to paint? in reply to Rod (NH), 11-21-2002 21:33:33
Now the forcast is for high around 60 and sunny on sunday.....darn college boys....that weatherman must have graduated from the university of alabama. What a job, four years of college and everyone expects you to be wrong....anyway the weather is unpredictible....hopefully, I'll get to spray this weekend...we normally get a few days in the 60's during the winter, but with work and all, don't know if I'd catch one for awhile. I'd hate to leave the tractor on jack stands all winter, I might need it for that 1 to 4" blizzard we get every 4 or 5 years....Thanks for the reply....Bill in TN
