Restoring Decals
jim
11-23-2002 18:38:41
Probably a dumb question , but is there any way to bring back faded colours in decals (David Brown 880)? Thanks for any input.
chris umphrey
04-02-2004 20:04:42
 Re: Restoring Decals in reply to jim, 11-23-2002 18:38:41
if you just want to brighten them up a bit you can take wheel bearing grease and put it on the decals and take a rag and rub it into the decals. that will bring them back to normal some.hope that helps.
Mark Myers
12-04-2002 16:40:06
Was this done at a Kinko's printing or something of that ilk, or did you take it to more of an industrial sign manufacturer??
Thanks,
Mark
Kevin
11-25-2002 07:49:30
jim,
If you are close to a sign shop you might be able to get new de-cals made there.
I took my hood to them and they laid a piece of wax paper on the de-cal and rub it with some kind of chalk and get the outline then run it through a computer and copy it perfectly and whatever colors you need,neatest thing I seen for de-cals.
250 dollars at dealer,they charged me 70.
Hope this helps,
Kevin.
jim
11-25-2002 14:49:28
 Re: Re: Restoring Decals in reply to Kevin, 11-25-2002 07:49:30
Thanks Kevin will give it a try !
