Overspray removal
Chris
11-26-2002 20:46:33
I understand I probably can't do this till warmer weather, but I have some overspray (black) on the hood of a tractor I just acquired. What is the best method to remove it without damaging the hood paint?
Gene Davis
11-30-2002 20:18:51
 Re: Overspray removal in reply to Chris, 11-26-2002 20:46:33
Rubbing compound and a buffer might do it.
Chris
12-02-2002 06:37:25
 Re: Re: Overspray removal in reply to Gene Davis, 11-30-2002 20:18:51
Thanks
David Maddux
12-13-2002 13:53:22
 Re: Re: Re: Overspray removal in reply to Chris, 12-02-2002 06:37:25
If the rubbing compound is working too slow and you think you are not getting anywhere you can wet sand with 1000# or 1200# grit sandpaper and then use rubbing compound. Dave.
David Maddux
12-13-2002 13:50:48
If the rubbing compound is working slow you can first wet sand with a 1000# or 1200
